Hi Guys
Back to the original question...,
IMO, I have not tried a clay bar I did not like..., they have all worked. Like everything else, it is a personal preference.
The Japanese have been using clay for quite a few years and Auto Magic was the first to import it and patent it..., which does not make it better..., just the first one that said "I saw it first" , LOL!!
I use clay on everything from new to old cars, and anything with paint and "bumps".
You can put your hand in a plastic sandwich bag and lightly run it over your paint..., if you feel "bumps", you probably need to clay.
My "routine" is to do one section at a time, in the shade, on a cool car/finish.
I always cut or rip my bar into several pieces(I can get about 10 pieces from a bar), as I flatten them out and they will go much farther and "if" you drop one..., you have nine left
You can use a quick Detailer, or, another "trick" is to use a good car wash with good lubing properties such as Zaino Z-7 and add a small amount to a bottle of water with a sprayer. It works just as well and you can save your QD for..., well..., QDing
Clay one section at a time, making sure to use plenty of "lube" to keep the clay from sticking, I clay about a 2x2 or 3x3 foot section at a time, but for starters you may want to start smaller until you get the hang of it.
When you see debris starting to stick to the clay, it is a good idea to fold it, flatten it and start claying again.
One thing you do not want to do is use a dirty clay bar..., so keep an eye out on the clay for dirt or foreign matter.
After claying the section, wipe it off with a good quality microfiber towel, as it is very absorbant and will not harm the finish or leave lint, plus it will remove any clay residue.
Next, check your work. If it needs more attention, clay again, if not, move on to the next section.
Once you get the hang of it..., it is VERY easy and also enjoyable to know how slick you are making your car
If you have never clayed, you will be amazed!! Your paint will become as slick as glass.
I always recommend polishing after claying, then adding a layer of protection to keep your slick finish "locked in".
Hope this helps
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
